I picked up a 1020 header yesterday. I was going to cut beans today but the plugs dont fit for the height control. This header was on a 1460 I have a 1640. do I need a new pot. or can I splice the wires. The wires on the header are colour coded but on the combine are all green. if I splice which wire goes where.
thanks great forum .
dave
The pot that you have should work fine. The connectors on the early 1400 series are different than the one used on late 1400s up to the 25xx series. You could splice the wires, but I would recommend just putting the newer style (grey Deutsch) connector on the header - this would obviously make it easier to disconnect. As far as wiring...
A- power (pink?)
B- signal (white?)
C- "ground" (blue?)
