Got a 2188 with a 1030 header. The reel does not run that smooth and when you start it will run fast but quite soon it will slow down and you are stuck with a limited speed. I have swapped switch's in case it is that but no difference. I have changed the return filter. Also auto reel speed does not work at all so I am always in manual. Any ideas ? If it was a 1460 (which we have also) you would say check the drive belt but this is not really an issue with the 2188
