After 30 or so minutes CR940 feeder house won’t lift
Leave about 45 minutes and try again it works
Doesn’t matter if 36’ Honey Bee is attached or not
Any ideas?
Could be hydraulic filters getting coated with crap then releasing it when stopped or a bypass when things warm up,
Can you hear fluid moving when trying to lift ?
Do all other hydraulic services on that pump work when it won't lift ?
Good point. Also can you manually push the buttons on the valves to rule out electrical..or if it’s a sticky valve
Have swapped HHC Module
Problem seems to be solved
CNH want almost $5000.00 for new module
Ooohhh Deere
Wrecker in SwanHill has done a few CR’s
Don’t know if they are compatible..........
