I broke up a hay ground, 2/3 of the field was heavy disk twice, 1/3 once. very good soil c, but it does range around the field. june 15 I brood cast seeded canola, just before a rain. Had excellent germination. did not get much rain. then the heat hit. when I checked it, it looked like one of them dry pressed flowers, that you would see in some book. it was all dead, there would be nothing to harvest. I called to make a insurance claim. agents were busy with hail claims. It be a month until they came out.The field got a good rain, and when agent came out the canola had started to regrow. flee beetle were craze, eating most of new growth.
Agent look at field and said 1. regrowth, was not normal for un-cut canola. 2. the leaves were not normal shaped. She claim chemical damage, so not insurance. She sent away a sample to lab to test it. It came back inconclusive.
The field has spot that the crop is ok, seam more parts of the field that was only disk once, any heavy clay. and there was less to no regrowth.
in the lower lying parts were snow melt water would of stayed, and were there is an under ground spring. there is regrowth and 5-10 bu/ac crop.
canola 233, last(2nd) spray was just liberty, I had sprayed round up, prior, i washed out spray with hose, then chemical cleaner, then rinsed. I did leave sprayer full of water over night, I do not think I put liberty in until morning.
I do not see a clear sign that crop was worse were head lands were over lap.
Has anyone had canola start to regrow after it been kill by heat and no rain? Were the regrowth leaves normal shape?
Thanks
Thanks
