We just started to try replace our broken countershaft. There is a clutch on the drivers side of the countershaft just outside the pulley for the wide 7 band main drive belt. Can anyone tell me how to get this clutch off? There is a ring of allen head cap bolts and 3 larger bolts with spring washers which we removed on the outside of the clutch. There are some threaded holes on the outside of the clutch that I was wondering if you put a threaded rod in to push the clutch off. Is this how you remove the clutch? Does anyone know how much torque the spring washers on the outside of the clutch are torqued to? Any help would be greatly appreciated. Thanks SouthernSK
