I read alot of your posts but don't say too much here, it seems like you guys can figure out some tough ones. Would you have any ideas on 3 problems I've been having on a 9650 Walker? 1. Header Height Display - erratic reading. This causes major problems with trying to map! I've changed the potentiometer (sp) but cannot get a consistent reading. Dealer can only tell me that I'm not getting proper voltage (supply) to the *meter. They suggest rodent damage in wiring. I've followed it as far as I can see and all looks good. There have been "aliens" under the buddy seat, etc.. Could my problem be in there? 2. Unloading auger does not go all the way out( it did in corn and wheat but not in 'beans or 'flowers) I've done the timing sequence and greased the heck out of it (while moving it). Are the guides the next thing to check? 3. Display for tailings return elevator blinks a constant solid bar (top horizontal meter). Sensors have been cleaned and look good. It worked fine in wheat but nothing else. the code comes up '1111' . Dealer suggests changing "master" sensor first, then "slave" sensor if the first doesn't fix it. I'd appreciate your comments if you have any. Thanks
