Has anyone ever converted a 3 position HHC system on an early series R62 to the newer unlimited height controller found on the '98 and newer machines? Would like to convert current header and combine to the newer system to gain more control on our 25 foot head. As it is now, the all the sensor arms are joined together as there is only one HH sensor on the left end of the header with the 3 spring set up.
Yea just order the infinite kit listed for the '98 and newer machines. You can convert 800 head back to infinite or if you have 500 there used to be a kit with instructions. Kit is likly broke down into individual parts these days. Don't know if you will see the benifit you are looking for unless you ground is very uneven. You could think about spring rod senser on both sides and wire up accordingly if realing needing both side to sense on that 25' head
it does work much better than the 3 pos switch I like being able to adjust sensitivity, and header height is much better especially if cutting in stubble, or green undergrowth
