i think we are gonna try it with our 676 rotary head...not sure if i can drive the reel hydraulicly with my harvester.
Jordan93 how is your machine set up to run the draper?
We're setting up our 676 head to cut cereal crops at the moment. Let me know how you get on with your head, as we are making alot of modifications and I am interested to see how you go with I assume minimal modifications?
We run the draper through two double acting hydraulic outlets on the chopper. The draper matt and knvies are run through the hydraulic pump connected to the ivloc box, and the reel (up-down, speed) is controlled through an electric hydraulic rate controller in the cab. We find with high moisture barley, the crop is so heavy that it overheats the oil. Normal moisture barley is fine though.
I've attached a picture.
