Thought my ideas might be helpful to those who are looking for an acreage sprayer. The only help was the local Hutts that did the welding for me. (screwed that up in my new garage-no power for welder..)Wanted to show off my new sprayer I built this spring, we built a new acreage and I wanted a sprayer that I could spray 2 products from, roundup along driveway, and around trees, and just weed spray on grass. I did not want to spend time cleaning it out in-between chemicals, since I work overseas a month at a time I my time at home is precious. So I designed and built one for my 2032R tractor. It has 2 33gal tanks, with 2 RV pumps, 2 sets of nozzles on the boom (1 set from each pump), breakaways, 3-section control (manual) pressure adjust, electric actuators (cylinders to raise wings) and also 1 handgun that comes from each tank, agitation (return from pressure relief/adjust) and the control panel that is within reach while sitting on tractor. I have a on/off wired in where the cable passes to the battery, and the battery has a permanent connection with a 2 prong plug so it is easy to plug and unplug when I hook it up. more pics to come...
Discussion Starter · #2 ·
more pics
more pics
more...
more pics
