1 - 20 of 27 Posts
I have been searching the internet trying to figure out what is an acceptable amount of canola seeds behind the combine and I am coming up with 400 seeds per square foot makes a bushel loss per acre. Can this be right ?? I am picking up a 18 foot swath with a 1680
· Super Moderator
That chart assumes a smaller seed size than what has likely became average with the hybrids now but unlike wheat which has a fairly narrow
range of seed size canola can vary by over 2 to 1, for example 3 to 7 mg/seed, whereas wheat tends to be around 40 mg.
I catch in a 3 sq ft pan, clean and weigh the seeds. Of course need to assume that chopper is not spreading back 100% and it tends to concentrate to ouside of spread pattern. Getting 0.5 gms per sq. ft. on average.
Do the math for 43560 sq ft / acre= 21780 gms/ acre, divide by 454 gm/lb= 48lb/ acre.
I assume that on half the spread so 24lbs/ acre, half bu. 40bu canola, 35' swath at 4.5mph. Seeds are too small to count. IMO
· Premium Member
In the STS book it's 822 seeds per square foot on a 30 header. That's on a 9750. We are running 5 mph in 45bu crop and using a 6.44 square foot catch pan chopper lifted and getting maybe 100 seeds. Was going to drop pan again today and weigh sample.
What are you running for a fan speed on your 9750?
· Premium Member
i am using a cf factor of 6 for a 18 foot swath and 100 kernels per sq ft 50 lbs a bushel 40 bushel crop and coming out with .16 of a bushel per acre loss using pami combine loss calculator
I think a 1680 sieve width would be about 1.2 wide & your swath width is 5.4 wide, so your CF would be 4.5.
You should also look at Havestcalc. Developed to provide answers to these questions quickly & easily.
At a seed weight of 4.8 grams/1000 seeds I calculate 130 seeds over every sq ft of the field is 1 bushel/acre loss. If dropping the straw to catch a sample and it was 5 feet wide for a 30' cut you would have to multiply the 130 x 6 to get a bushel. So in this example you would have 780 seeds/sq ft. If catching on the ground with the chopper and chaff spreader running it gets much harder to figure out.
1 - 20 of 27 Posts
