The pin that goes through spiral is tapered so you need it to come out same way it went in, however you may not be able to see pound marks on pin, if you can just pound on opposite side. My method is vise grip a Heavy punch or a good air hammer and pound both ways until it starts coming out then may need smaller punch to continue, usually a couple blow with 2 pound hammer will remove from shaft. Install new pins
