1 - 1 of 1 Posts
I need to know the expected flow rate in the hydraulic circuit that adjusts most things on the 9870. On the 9770 this flow rate is 4.4 GPM. I need to know if this is the same in the 9870 or not.
I build an aftermarket kit to prevent dust ignition and frequent smolders in volatile crops (sunflowers). It requires a hydraulically powered blower and I use a the hydraulic flow in the above circuit. To achieve safe and effective fan speed I need to know the flow in that circuit. I'm pretty sure it is in the tech manual TM101819, but I don't have that document.
DSH
1 - 1 of 1 Posts
