I assume that the pickup on your pickup header is belt driven and not hydraulic. Some of the older MF combines did not have the hyd reel pump system on the combine. What are you doing with your current straight cut header? If you are scrapping it would the hyd system fit on your new header? The only other way would be to get all the reel drive pump systems parts of a wrecked unit and install on your combine.
