Thanks, I didn't think about a truck engine being different. The burned engines I found are from a 7140 and 2388. Yes, the PTO gears would need changed if I used a 2200 rpm engine, most every thing else is the same, starter, radiator, flywheel and air cleaner. Would need engine mounts, fan, fan shroud and hoses.
