1 - 2 of 2 Posts
Could one of you folks kindly tell me the point gap, plug gap and advance specs for my Gleaner K. It's the old Chevy 6 engine (gas). I believe a 230 cid. Thank you in advance.
Depending on age I think....seems like later used GM's HEI ignition. The BIG distributor cap with the ring on top of wires.If that was what you have there'd be no points and spark gap was wider.(45?) old school would be something like .020" points and .035 plugs. Check timing before you mess with it and set it there if you can't get the spec. It would be a 250 in a K....the F's had the 292
1 - 2 of 2 Posts
