Everything is operating on the tractor as it should but It will not lift any of my implements when hooked to the remote box. I removed the inspection plate at the back of the tractor and had someone operate hydraulic lever inside cab of tractor. When the remote lever is engaged hydraulic oil sprays out of the inspection plate area. Has anyone had the same issue or any idea what the problem is? Thank you
