I have a 2166 without the adjustment for the head leveling. For some reason it is dragging slightly on the left side with my 1020 head. I have reset the head as to the manual helping some but i am still experiencing the problem. Has anyone had this problem or have any suggestions on how i might be able to fix this?
Have you checked the springs holding up the dividers? If one of the sides is different from the other it could drag one of the sides of the head lower. They should sort of "float" on the ground, reason I had to change ours is one of the dividers would bulldoze instead of ride over bumps, but go too far and it could cause the divider to ride high but make that side of the head dig into the dirt. Perhaps check and see if one divider rides high off the ground and loosen the spring and see if that helps? However if you have already done so than not much else I could suggest.
