Hello everyone,this is my first post on The Combine Forum.
My Dad has a IH 715 Diesel combine,not sure what year? Late 60's,early 70's? He purchased the 715 about 3-4 years ago,this year he's having problems with the engine shutting down.
It seems like while idling or unloading grain the 715 will run just fine,but when he's combining(full throttle) the 715 will run about 300-400 yards and just die like it has run out of fuel? He'll wait a few minutes turn the ignition on and we can hear the electric pump,which is pumping really fast like it was out of fuel? Then the pump will slow down like it has refilled whatever part was starved of fuel? The 715 will start right up run another 300-400 yds and quit running again? With the same symptoms has described above.
I also need to add that Dad did replaced fuel filters this year prepping the combine for the harvest season.
Murphy WD-300LV
The original owner had a Murphy WD-300LV engine panel installed after he let the combine get hot and lost a engine head in the early 80's. This control will shut down fuel supply if loss of engine oil pressure or hot engine temp. conditions.
So we thought maybe this was the problem? Dad wired around this murphy wd-300lv engine panel and the IH 715 still has the same symptoms described above losing fuel supply while combing.
Any ideas or experience with this type of problem would be greatly appreciated,we have little experience or knowledge pertaining to diesel engines.
Thanks,
FamerKMO
Here's links of the murphy control/wiring diagrams that the original owner had installed that we thought was giving the fuel shut down problem.
WD300 Series | Murphy by Enovation Controls
http://www.fwmurphy.com/uploaded/WS-93002N.pdf
Murphy WD-300LV
Thanks,
FamerKMO
