Okay, Compressor on the 1420 is not cycling as it should, refrigerant pressure light is on in cab which leads me to believe the low pressure cutout switch is made up, tried to add 134, finally got it to begin to take a can, compressor will only run when I use a jumper wire to make it run, otherwise it will never kick in to cycle the refrigerant I'm trying to add... what gives?
