1 - 2 of 2 Posts
I have a IH 1486 and I noticed the AC compressor has a little film around the clutch. I wanted to check the oil level in the compressor crank case, so I started to unscrew the bolt plug on the side, but when I did, pressure started to come out, so I tightened it back up. This is were you check the oil in the york style air compressors right?? Thanks.
1 - 2 of 2 Posts
