By the time all parts purchased before labor and machining we are around $22000.... So let your imagination do the rest. New Reman from Deere is 49500 with warranty.No help to you but I'm interested in what it cost for the parts to overhaul one.
Thanks I already called them and yes they have 3-13.5 liters but no 12.5 liter with model I need.All State Parts in SD may have one call 877-530-4010. They also have 3 13.5 engines. Diesel Engine Trader shows a few including a reman at IPD phone # 866-623-1978. I don't know anything about these engines or sellers I just searched the internet and found these engines. I hope it helps. I use a 12.5 in my Deere 6750 Harvester.
6750jd
Would that matter?Thanks I already called them and yes they have 3-13.5 liters but no 12.5 liter with model I need.
Yes electronics are different from one engine to the next plus head for 9620 is different than say a smaller model....Would that matter?
Wouldn't it just fit up?
Or is there electronic issues matching?
Come to think of it I remember in 1998 I had a 9400/12.5 that wouldn't start.
Tech brings out an ECM, tractor started as normal and throttled up...once.
Since the ECM box was for a lower power rating the engine would only idle.
Thus completed our parts shelf diagnosis but a new matching ECM had to be ordered.
I don't know why it wouldn't run on the robbed box off a lot tractor.
Hope you get fixed up.
By the way, in this age of alarms and electronic limiting how does one "melt down" an engine?
