At the bottom of the auger there is a cover with 4 5/16 bolts holding it on. Remove the cover. Loosen the 4 3/8 bolts that hold the bearing flanges on the bottom of the auger. Take loose the top bearing support. Pull the auger out. The auger is driven by a splined shaft, it will need to be aligned when the new auger goes in.
