Questions for those of you running independent opener drills (disk or hoe). How do you go about setting the drill in general? Let's say we're seeding canola at 1/2". So first you set the packer wheel on each shank to be a half inch above the opener, correct? Then let's say you do a test run and start digging in the soil and find the seed is too shallow. So do you just increase the packing pressure? Besides setting the initial depth, when do you adjust the individual packer wheels?
I'm just trying to figure out the advantages of the independent opener over the standard air drill that I have (flexicoil hoe drill). From what I can see the main advantages are that that it allows the use of disc openers (though I'd probably stick to hoe), follows the terrain a little better, and when you turn you lift the packer wheels right off of the ground so you reduce compaction on the head lands. Is this accurate?
Are there any disadvantages you've found with the independent opener drills (besides more bearings)?
