1 - 13 of 13 Posts
We have been growing a combination of InVigor 252 (swathing) and 140 (straight cutting) which has been working good however, we are considering going to all 140 as we do see a ~8% yield increase. We like the idea of swathing some to not delay harvest so we are wondering if 140 swaths as good as 252 or other varieties and if anyone has had any issues with swathing it?
I swathed some once due to a gate being left open and 200 yearlings flattening a field at the end of flowering. I was not looking forward to straight cutting it. Swathed it at 80% SCC and worked good. Could get aggressive with the reels and the only shelling was on the dividers.
I have swathed lots of L140P at 100% seed color change, basically taking the green out of the stalks so combine would put through easier. It works great if you have a swather that can handle it. First year had a 1203 Case and it did OK, second year a MacDon and did not go well unless wet from dew or raining. Third year an AGCO WR9840 with cross auger on the header which worked great. I think if I had a cross auger on the Macdon it would have helped. Some pictures in this thread: http://www.thecombineforum.com/forums/13-headers/244442-cross-auger.html Those pictures actually show a bit of color in a dry hilltop that came up uneven, most stuff was dead ripe.
I would never swath at anything except 100% seed color change with a "P" variety, that would be a waste of yield potential. If you don't have time to swath it then just straight cut it.:smile: It stands better with lower seeding rates and has been a great variety for me.
I would never swath at anything except 100% seed color change with a "L" variety, that would be a waste of yield potential. If you don't have time to swath it then just straight cut it.:smile: It stands better with lower seeding rates and has been a great variety for me.
You mean an Invigor “P” variety right? Some L varieties (non - “P”) do not swath as good at 100% SCC....
Everybody keeps on saying yield gain with the straightcut, but our 252 outyielded our l130 and l140 by a fair 10bpa, combining took longer on the straightcut but sample was bit cleaner (0.4 dockage difference).
Fuel use per acre was actually higher on the straightcut as well, plus not including the cost of the roundup and heat, we also harvested some not sprayed, woef plugged the combine few times.
Seen some big guys in our area growing lots of 252 and wondered why they swathed so much in harvest but after we were done i knew why. But other peoples experiences may be different, defenatly not selling the swather.
Discussion Starter #7
Thanks very much guys, this helps our planning. We have a Macdon without the cross auger and had heard of similar findings.
Two years ago we got a hailstorm and the L140 out-yielded L252 by 50 BPA! That pays for a lot of seed! I did trials with 252 for a couple of years and didn't find it to be any different than L140 when they were both swathed at same stage, and those trials were on same field.
L252 is a good variety but it's just not shatter resistant.:frown:
Lol thats an extreme case but ill take it, l140 standabilty if junk, absolutely flat on the ground good yield but **** made slow harvest
I guess we truly have different scenarios if yours is lodging bad at low planting rates. You are planting at 2.5#ish?
Yeah that hail came at the worst possible timing I will agree. A LOT of people in this area converted to L140P after that happened.
Depends on how thick the crop is. We've had 65 to 70 bpa L252 and despite the pods not being shatter-resistant, it stood up just fine even in wind, and we were able to straight-cut it quite easily. Seems like if the crop is somewhat thick and you've got lots of intertwining of the pods and plants, regardless of variety it seems to resist wind fairly well, within limits of course.
I know SW Man been talking about importance of low planting rates for sometime and actually think there some sense to this with all varieties of canola as lower the planting rate the more of your yield seems to be from the lower branches that believe somewhat protected from weather. Guess until get a Spring issue that does more than scare a person looking at crop into early June likely this a good strategy - IE think if you get a thin enough stand does not matter how big bottom branches are if space between plants allowing weather to hit all branches. Other big advantage on "thinner" stand is disease control(or none needed) as well. If all goes according to plan I may have bit of a "farmer" test this year on this. Plan to plant some canola with conventional airseeder, rates, and than most of it with planter. However, will be different variety, different time of planting so certainly too many variables for scientific crowd.
1 - 13 of 13 Posts
