1 - 9 of 9 Posts
Yes. Many times. It just keeps coming out to the same position once I run it, so I'm assuming this is the normal running position, but of all the machines I run, I've never seen one do this with new/ clean filters.
Also the engine seems to run tip top, and I checked for any other blockages in the intake system and found nothing.
I checked for blockages and didn't find anything, but I'll check again. Maybe I'll try another restriction gauge to see what happens. My main questions was if this was the normal running position or not but I guess I got my answer.
My 23 was doing the same thing and ended up being wet debris stuck on the venturies which dried and blocked off 70% of the air flow. Had to tear the entire air system apart to locate and was tough to get out of the tubes.
John
1 - 9 of 9 Posts
