Ok riddle me this Batman
Got a 2375 and in 4 years I have replaced the low pressure switch on the AC. Any idea what could be causing it to die? Cleaned the cab filter.
Thanks
It's warm enough there to use AC this year?? I haven't turned mine on once yet.
Discussion Starter #3
Hehe going to be 22 here today
Had that issue on my 2388 and I just unplugged the switch and plugged the wires into each other never had a problem since . Only there for icing of the condenser and running out of Freon . Little different on the high pressure switch though .
I wouldn't jumper it... because someone will leave the compressor on with no refrigerant in it and cook the pump, contaminating the entire system....
So, you replaced the switch once?
And it's gone a second time?
Is the charge low? Or are you just assuming the switch failed again?
Discussion Starter #6
Switch is pooched. When the tractor is just ideling the ac works great. Once I put load to it it does not.
Put in a new switch and works great
Discussion Starter #7
Once I move back home I’ll try charging the system. Could be operator error?
