101 - 115 of 115 Posts
Hi all! I'm a farmer from Uruguay S.A. I have an big problem with w pump. Of my 9860 combine. Bearing destroy the distribution of the engine. Any have idea to buy all kit?
Dealers and Deere should be ashamed of themselves for not following up all these early waterpumps and rectifying. The damage they have done to their reputation is immense, so stupid. I will never be buying another high power Deere engine after the trouble I had with mine.
When I had bought a JD 9430 used, the local dealer suggested I replace the water pump to be proactive. Its the 13.5 liter engine so I don't know if the very same pump fits the 12.5 but I believe the failing theme is similar in that it can allow the balls to fall out of the bearing into the engine. The updated reman pump I bought has a different drive gear on it with a machined surface on the backside that makes a close fit to the face of the bearing or that is what I was interpreting when comparing them both side by side. Will that solve all problems, I don't know but it is the update they came out with. They suggest replacing the pump on a regular basis, some suggested 3000 hours and some said do it even sooner. Its not a cheap unit but if it saves that mess in the photos, I guess its worth it in the end.
I don't know if the bearing is different or not, I was not able to find out from anyone at the local dealer as to what was all different about the new/reman pump. And again this was for my 13.5 liter engine so one would have to dig into it to find out if there is an update on the 12.5 pump as well.
An engine can fail in any machine. It is common for a dealer to say "oh never heard of that happening before". It is kind of a brand loyalty problem, "that isn't a problem with our stuff" attitude. Truth is every manufacturer has its gremlins. Just not quite as catastrophic as this usually. Dodge eco diesel has the odd motor grenade at 140,000 km from a gear that slips that drives the oil pump/camshaft on passenger side head. I was on a forum and found a place in the states that bullet proofs this problem for $2500 and a one night stay across the street in a motel. So I figure if I can buy one cheap enough a trip to the states is in order. I am at a local dealership looking at a used eco diesel one day and I tell the salesman of this issue and he said he never heard of it before. 3 weeks later I stop in and he says he has an eco diesel real cheap. Turns out a customer had a grenaded eco diesel. Now the salesman believes me. I know of 3 deere combines that had engine failure here over the past 3-4 yrs. One guy had his last hopper of grain heading to the grain truck to finish the yr off and wham lol.
Problems can and do happen. It is what companies do when the problems start. With all the information available today a guy would hope these problems become fewer and fewer. I never take a sales guys word about equipment I go back to the shop and talk to the techs and see what they have seen already
Have the pump bearings been redesigned so that it isn't an ongoing problem?
The pump I put in my 9220 a couple of years ago did seem to have a tighter gap between the casting and the shaft behind the drive gear to contain the bearing pieces if a failure occurs. The original pump had a fairly large gap around that shaft. So I assume this is the redesigned pump.
So when the bearing fails on the new style does coolant leak to give you a warning that pump is failing or does the shrapnel just keep getting ground up into smaller pieces. How do you know it is time to change the water pump now?
There is a drain hole where coolant will drip out of if the seal/bearings are failing. Only problem is where there is moisture in dusty conditions dust will mix with moisture and gradually block the hole. And that's the end of any early warning!
The problem with even caging the bearings better, a catastrophic failure can still occur. This is a gear driven pump that wont stop for nothing. Unlike a belt driver one where the belt will slip and you will hear the squeal or the belt just grenades. Pieces are going to break, just which ones.
That is still a pretty questionable setup. Gear driven water pumps were supposed to be more reliable because gears are more positive and reliable than belts in the long term, life of an engine picture. Is this bearing the initial problem or is it coolant that starts to leak and bearing failure is the result? Bearings have a design life. A design engineer needs to select speed, load, operating conditions and there is a bearing that will run anywhere from a couple of thousand hours up to a possible hundreds of thousands of hours. The cost of a better bearing is only a few dollars vs a $75,000 engine and then the damages of the owner not getting the work done that was the reason for buying the equipment in the first place. Seems like a design flaw that has catastrophic results way too often.
Detroit S60s have been using gear-driven water pumps for years. Are they catastrophically failing from time to time also? The Deere 12.5l is based on the S60 if i'm not mistaken.
I have never owned or driven a 60 series but have never heard the problems with them that JD has with water pumps. I have also heard the rumors about some commonality between the 60 and JD???
Correct. I believe the engine came out of a joint venture with Detroit. The 12.5l is based on the S60. The block design is nearly identical. The gear train that drives the pump is nearly identical to my S60 in our Freightliner. You can even see the spot on the side of the John Deere where the air compressor would have bolted on.
Thank goodness for this site, I replaced my water pump on my 9760 combine before a disaster. Noticed , the Pump was leaking when the unit was apart. also noticed the drain hole was rusted shut. So yeah, no early warning sign of a leaking pump. This is not an easy job. Very hard to pull off pump, propeller broke off pump. 2978 HRS on engine. Took two days to fix, so yeah would not be a fun job at harvest. I think its good preventable maintenance regardless! Bearing was rough so I can see how the balls would cause significant damage if they fell into the engine. I THINK its not a good design.
