I am new to JD and picked this drill up for $20 grand less than what is on dealer lots. It's a 52' with stealth paired row openers and steel packers. The cart is a 1900 but I was told it had 1910 meter boxes.
What I like;
I love the greenstar display. Calibrating was a bit of work but once I had it figured it seeded very accurately and was user friendly.
I really like the tool . It moves a lot of dirt compared to my old drill but it powered through all the hard spots and I found folding and unfolding a breeze. It's tall to tow down the road but it also roads really nice. One rocky field when the shanks were tripping out a lot the hoses started to fall out of the manifolds but a screw seemed to stop the worst offenders.
What I don't like ;
The cart, specifically the 8" auger. I have hopper augers on the trailer so I only like to make one stop since I hook the augers to the drill for hydraulics. I found if I fill the middle and back tank first with fertilizer, then move the auger to the front tank I can pull ahead with the truck a bit and still make the hopper. It's a terrible designed auger as well as the placement of the tank lids. To make matters worse someone put an air seeder hopper on it and now it can't be swung back under the cart to unload. The meter shut off levers are sticky and if you try and dump grain hits the air tubes and bounces everywhere.
I like the fact you can easily pull out the meter cartridges but if you cant get the cut offs closed its a mute point.
The slides that choose between top and bottom shoot can only be moved with a hammer on the fertilizer tanks.
The air seeder hopper is cracked and needs replacing. My question is would it be worth going back to a stock hopper ( at great cost ) or were they junk too ? I can put a replacement air seeder hopper on for about $350 but then I can't unload the tanks with the auger.
I'd like to hear from JD owners on their thoughts and advice based on experience.
What I like;
What I don't like ;
