1 - 2 of 2 Posts
The warning lights in the Investigator ll monitor system on my 4450 are not operating correctly. One or more come on with start switch in "on" position, and they can be turned off by simply cycling the start switch. I've read about cab grounding problems. All connections were tight on the unit. Has anybody found the solution? And where exactly is that ground wire from the cab?
1 - 2 of 2 Posts
