Is there anyway to adjust the rate of drop, it raises fast enough but sometimes have to stop and wait to let it catch up when going through uneven terrain. The header is mounted on a '13 S690
This is when its in flex mode
I’m not sure but aren’t those paddle switches five position? Hold at centre, first click either way up or down slow, second click either way up or down fast.
There should be a button on the armrest that has a side profile of a header with a rabbit/turtle on it. The first time you press it you can raise the manual speed which also makes it faster in auto mode for the lower.
The second time you press it is for auto mode speed/sensitivity.
Third time is contour master sensitivity and fourth time should be contour master tilt speed.
Hope this helps
