1 - 1 of 1 Posts
Hello,
I have a problem in my 6610 forage harvester. When I want to start automatic knife sharpening cutterhead start to rotating for couple of seconds, then 228E error appears on Info-Trak monitor.
228E Desired program cannot be activated because cutterhead is not rotating. Turn Iron-Gard switch (S39) off, try again. Check if solenoid valves for pressure build-up and for reverser motor are correctly supplied with current. The cause could also be a hydraulic problem. Should the message appear although cutterhead is rotating, check cutterhead speed sending unit and wiring (see Section "Feeding System"). Check manual switch (S53) below cab.
I have checked all connections, stone moves in manual mode. Speed sending unit also is OK - it indicates correct rpm.
Is it normal that solenoid valve works like on linked video ?
Thanks in advance
Wojtek
1 - 1 of 1 Posts
