Rawson is owned by Trimble now. Trimble's website is terrible, but they do have .pdf files of installation and operating manuals. For some reason I can't get the files to display properly, but maybe you'll have better luck. There is a process to calibrate the Accu-Rate. It seems complex at first, but once you do it a few times it becomes simplicity itself. I do it all by muscle memory so I can't really type it out step-by-step, but hopefully the manual will download properly for you.
Trimble – Rawson Drive | Trimble Agriculture
http://trl.trimble.com/docushare/ds...TEController_9.2A_UserGde_USG10333_ENG_AW.pdf
As for your rate problems, there could be several things wrong. In no particular order: make sure it's calibrated correctly, make sure the ground speed is calibrated for your tractor, and see if the double reduction sprockets have been installed.
edit: I got the manual to display correctly. I had to open it directly with Acrobat Reader, not in a new tab in Firefox.
