Had two closely related and very inconsistent issues with our 8310 last year during seeding. Just wanna see if I can get it fixed for this year before we get started seeding. Here are the two codes that I got
CODE ECU 54 - Intermittent loss of Engine Control Unit (ECU) power supply
CODE PCU 5 - Fuel flow signal from ECU missing (Warning)
Stalling
The tractor would stall just for an instant (like 1 second) and then come back up to operating rpm (1800rpm). Sometimes it would do this multiple times in a day or sometimes just once in a day, I even went 2 full weeks without anything happening. It did this maybe 15-20 times in the 150hrs of work last spring. and 2 of those times it stalled completely and needed a restart. It was inconsistent in when it would happen
Revving
The tractor would be pulling just fine when all of sudden my transmission light and warning come on and the tractor goes right up to max throttle so my first reaction is to shut tractor off immediately. So I would wait a minute or so and start it again just keep going and it hasn't happened as much as the stalling but still just as bad of a problem. This maybe happened 3 times in 150hrs.
I already replaced fuse F12 and swapped relay K13 and that didn't do anything. When it warms up a bit I will try putting some dielectric grease in the plugs on the injection pump and hopefully that fixes it but I somehow doubt that is the problem. Has anyone else had this problem or provide some insight for what to check next
Stalling
Revving
