Hi, my name is Mark and i am new here.
I have a problem with my 9520. First i have CODE CCU 65( Axle lube pressure low ). i have removed the pressure switch sensor and i wrapped my oil pressure gauge in the hole. but i measured to high pressures. by idling 3 bar(45psi), but by 2000 rpm 15 bar(240psi) and fluctulate.The filter and oil is clean. Have you any idea what could be wrong? Sorry my english is not good...
Thank you!
