Hi all,
Have a 9760 JD and having trouble with fires (approximately every 300 yards) when harvesting chick peas.
Just wondering if anyone else has had a similar issue and if so, how they resolved it!
The machine was purchased with a Midwest 40 foot crop hawk front fitted. It also has a stainless steel rice kit fitted to the internals.
A neighbour has a later model JD and can be working side by side with us and has minimal issues.
The best we can come up with as to a cause is the following:
1) Static electricity causing a spark (something to do with the stainless steel rice kit fitted)??
2) Alternator earth is intermittent causing a potential difference??
3) There is a potential difference between the front and the header - may be necessary to fit earthing straps from front to frame of header) assuming the pivot point for the front is not providing a reliable earth
4) Dust/fluff is igniting against the exhaust and dropping into the head. (We have wrapped the exhaust with insulated exhuast foil but has not resolved issue)
5) Oil in hydraulic pipes heating to a point causing dust/fluff to ignite (may need to change the grade of oil)
ANY suggestions/thoughts would be greatly appreciated
