Hello, my 4020 with synchro seems to be stuck in gear, it's in gear when the lever is in neutral and pulls hard when u put it in a gear. The shift lever works and feels fine as long as the clutch is in. What am I dealing with here? Can a guy work on tranny through the bottom of the cab floor? Any help would be appreciated. It's a 1970 model. Thank you!
Those shift levers are notorious for getting clogged up with dirt. Open the bottom of the dash up and shine a light down there. There should be some openings to let the dirt out that are probably clogged and stopping the levers from moving as they should. Check the PTO linkage while you're in there or you'll fry a PTO clutch too.
