Just wanting to know if I should be worried about my John Deere 8320R suspension creeping down overnight. By the next day it is all the way down. Dealer doesn't seem to be too worried but I'm nearly out of warranty so if it's a problem would like it fixed.
Mate if I were you I would disconnect the rod end hose at the end of a day and see how much leakage there is. As a jd field tech I have had an instance where one side fully leaked down and the internals of the cylinder were stuffed. This leak test should be able to be carried out under warranty as it is an actual test in service advisor
