We have a John Deere Combine 9500. from 1996.
What is the problem when you switch to to half engine speed nothing happens? it only work on idle and full speed.
Jens; There is a resistor that gets switched in when you put the switch on "half". Its the 2K from pin 5 to ground shown on the schematic. WIre 143 is the throttle control wire: Idle, its open circuit, full throttle its shorted to ground, and at 1/2 its got the 2K to ground. Note its a special switch.
I would guess that someone put the wrong switch in, or the resistor is broken.
Discussion Starter #3
Hi Jeff.
Thank you for the information,
We will have a look at the switch.
