1 - 2 of 2 Posts
The combine was running perfectly until the lights were turned on and it then cut out and won't start again. It's a 96 2058 combine. Any suggestions what problem can be? Or has anyone had similar problem
That model is not a common one that I have schematics for. However, it sounds like the main "feed" to the cab//controls has failed - the failure point is gotta be in a common circuit (Ie near the battery power source) for both the lights & starter to quit at once. If this was a 9510, I would say the main "Cab power" contactor by the batteries had failed. I would suggest starting at the batteries and trace the power forward to the cab with a testlight or DVM.
1 - 2 of 2 Posts
