1 - 10 of 10 Posts
· Premium Member
He is smart to unhook the head and pull the combine out, then get the head out after.
There was another make of combine that got stuck north of York, Ne. and just a few miles from were i work at Osceola, NE along Hi way 81 They were told by there dealer to take the head off or the combine could be damaged, the CAT dealer took a CAT excavator to get it out and then the head.
Quote:how come the brits get all the good combines, that usually have tons of horsepower, more electronics, faster that bigger this, and we get the base models.
Not just Brits, but ALL Europeans.
Dang, I want an i-bine, too!
· Premium Member
This CTS combine is still produced in the JD factory plant in my hometown Zweibrücken/Germany,this combine is now called C 670,
http://www.deere.com/de_DE/products_ag/combines/c_series/index.html
has 400 [email protected] and 440 hp max.You can order this combine with a factory installed hillside leveling system called hillmaster 2 as well as the STS combine,called S 690 with 530 [email protected] and 563 hp max.
http://www.deere.com/de_DE/products_ag/combines/s_series/index.html
But for harvesting small grain in wet and/or green straw conditions the have now the ultimate solution which outperforms the northamerican STS combines easily,the new T-series combines with an additional separator drum,the largest model,the T 670 has a 400 [email protected] and 440 hp max. engine,i hope mother Deere will offer these combines in the US and Canada,i am sure a lot of small grain farmers would prefer these combines over the STS.These T series combines are also available with the hillmaster 2 sidehill leveling system.
http://www.deere.com/de_DE/products_ag/combines/t_series/index.html
· Super Moderator
Quote:This CTS combine is still produced in the JD factory plant in my hometown Zweibrücken/Germany,this combine is now called C 670,
jaydee
Thanks your description and the links on these machines.
I asked sometime ago how any rotary machines could be sold in Europe as I have observed the severe feedrate reduction due to green and/or tough straw. And you have far more straw than most of North America.
Pretty well tells the story when you suggest a 400 hp machine will outperform a 530 hp machine.
I think you mean the ultimate "John Deere" solution, I imagine a 600 would run circles around a T 670,
both in through put and losses.
Don
· Premium Member
Yes Don,you are right,the Claas Lexion 600 is far ahead for capacity,even in tough conditions.I dont understand the Deere guys-if they would take the CTS concept and adapt this system to the wide feederhouse,the threshing cylinder and the bigger cleaning shoe of the 6 walker combines,including a 550hp engine,i would say that this combine could come close to a 600 for capacity,but mother Deere does not allow the R&D guys here in zweibrücken to built a prototype like this...
1 - 10 of 10 Posts
