has anyone tried this yet?... i will be when i get home...
Good dayThat's correct, unless you're using the ITC Extender or equivalent.
I tried it tonight and it works as advertised. Acquired WAAS after just a few minutes and no other functionality was removed. The ITC Extender (well my own home-made version) still works also, which is good news for folks who want to keep using the ITC for a few more years.
Dia bom
Você pode, por favor, ser tão gentil em me dizer como você fez seu próprio extensor itc. Eu realmente gostaria de usá-lo novamente
JJ Lyon
[/CITAR]
OLA BOA TARDE PODE ME PASSA PRA MIM TESTA AQUI NO BRASIL O EXTENSOR ITC PRA VER SE DA CERTO .....
It's the opposite. The extender fools the tractor into thinking the receiver is getting SF1 when in reality it is hopefully getting WAAS or EGNOS. SF1 is higher quality than WAAS or EGNOS, and that is what stopped working on the ITC.I'm from South Africa
As far as I'm aware we should have WAAS signal.
Correct me if I'm wrong but I think an itc extender tricks the system into thinking it is using waas signal meanwhile it is using sf1
But I think we do have waas signal so I would like try.
não tenho e não sei fazer
[/CITAR]
MU AMIGO ALGUMA FOTO DO SEU PRA MIM VER COMO
Ok thank youIt's the opposite. The extender fools the tractor into thinking the receiver is getting SF1 when in reality it is hopefully getting WAAS or EGNOS. SF1 is higher quality than WAAS or EGNOS, and that is what stopped working on the ITC.
I know for fact you have no WAAS coverage. That's north america only, covered by three geosynchronous satellites and using ground stations in the United States and Canada. EGNOS I'm not sure about; you might get some coverage down there. I'm getting conflicting information from Google searches! Send me a pm with your e-mail and I can discuss it with you what hardware you would need to make one.
Even without the extender you should be able to turn on your ITC and see what kind of signal you are getting on your John Deere display. If it never says anything more than 3D+, then you're not getting EGNOS corrections.
É o contrário. O extensor engana o trator pensando que o receptor está recebendo SF1 quando, na realidade, espera-se que esteja recebendo WAAS ou EGNOS. O SF1 é de qualidade superior ao WAAS ou EGNOS, e foi isso que parou de funcionar no ITC.
Envie-me uma pm com seu e-mail e posso discutir com você qual hardware você precisaria para fazer um.
Mesmo sem o extensor, você poderá ligar seu ITC e ver que tipo de sinal está recebendo em seu monitor John Deere. Se nunca disser nada além de 3D+, você não está recebendo correções. É possível que os receptores Deere chamem qualquer sistema de WAAS, mesmo que seja realmente EGNOS. Então, se você vir o WAAS 3D, com certeza é bom.
[/Cbom ITAR]
EM QUAL EMAIL ENTRO EM CONTADO .... AQUI NA MINHA ANTENA ITC ELA APARECE NO MONITOR 2630 ASSIM 3D+
CARREGA ATE 20% PRECISAO
SINAL DO GPS CARREGA NORMAL
SINAL SF (DB) CARREGA NOTAL TAMBEM ]
[email protected]
I'll pop off an email a bit later today.
Can you plase send me that email as well thanks jonathan ! [email protected]I'll pop off an email a bit later today.
Hi Torrien, Could you please let me know what is needed for a homemade extend. [email protected] Thank very much!I'll pop off an email a bit later today.
