1 - 12 of 12 Posts
Looking into buying a RX 4 track. They have been out for afew years now, should have some with afew hrs on them. Wondering how they are holding up? Any issue of any sort? Idler wheels? (i dont see any clear caps on any of them.Maybe no issues?) Any info of what to look for would be appreciated..
We have 2, 9620, Cummins. About 1600hrs. Pull drills, grain cart, harrows, protill, pulldozer.
No major issues, some emission/def issues. One uses more def than the other, runs out before fuel most times.
Hoods heavy to open/close
Can’t see hitch from cab due to pto
Pulls strong, rides smooth, cab is comfy, not as quiet as it should be.
If buying used, make sure transmission PIP is done, along with cab noise PIP.
Tracks seem to be holding up well.
We like the auto shift feature, works very smooth when seeding.
Just bought 3 last fall. Going to be pulling new 76 ft Bourgault drills. 950 cart. So a waiting game now. Hope they run good. No electronic issues, hopefully.
i demoed a used 9620rx last fall, if the price tag was a little more friendly , it woulda stayed
Defiantly the Cadillac of the 4wd market ,
Here is another one with the John Deere pros and cons. I think if I was in the market for a quad track, I would go with the Case IH...but that's just me! One other pro of the Case IH is that it is probably at least $100k less in price!
A 12 litre Iveco can’t compete with a 15 L Cummins ,
No replacement for displacement
Like sending a small block too do a big blocks job
look for one with the axle spacers because the mud buildup between axle and frame is an issue the tracks start rubbing against the mud and they are a bugger to clean
case has alot of things figured out on they're machine, having said that if you're a green guy don't buy red you'll never be happy anyways.
1 - 12 of 12 Posts
