Does anyone know of a company that builds hopper extention s for l2/3 gleaners. would like too add some capacity to it with a 8 row corn head. thank you for your help and advice.
Does it have the extensions that flip up when the tank fills? I would be worried about the excess weight but its probably been done
I had thought a lot about this a few years ago. It would not be hard to make the extenstions, and even have them move up and down with the factory ones, the problem is the tank fill auger. It pivots on a U joint, and that U joint is basically at max operating angle when the auger is all the way up and tank is full. To push it farther as is isn't a good ideal. You would need to rework that auger to make it work. Also note that the first place you will fill up is the back right corner where the clean grain auger comes up. Getting that figured out as well as making it accessible will be an issue as well.
That's my $.02, take it for what its worth. Get a better grain truck/cart driver.
