1 - 11 of 11 Posts
Due to the cluster **** of a spring we've had, got a section of mid June seeded hrsw that unevenly emerged and is in the 2-4 leaf stage. Initially was canola which then froze and got raped by flea beetles simultaneously.
It got a .75L of 360 gly way back in early May and then wasn't touched again till now. The boys went and drilled wheat into it and I never got around to giving it a proper burndown before the wheat came up.
Currently a carpet of big juicy dandelions and hawksbeard and the odd surviving canola plant.
So basically my question is, if I'm giving it a full rate of Dyvel (6oz/175ish g MCPA, 1.5oz/42.5g banvel per acre) and 3g/ac of Ally/Metsulfuron, can I go back in when the wheat is fully tillered and hit it again with 24d to really burn down the dandelions?
Discussion Starter #3 (Edited)
We re so dry I'm more concerned about them sucking moisture all summer vs the yield drag from the 24d. Just don't want to fry a section with too much chemical.
Assuming they survive this first round of chem of course. Just kinda want a contingency other than just pre harvest dessication, although that will ultimately be in the cards anyways at this point.
Discussion Starter #5 (Edited)
I guess if you stage it the best you can on the majority of the wheat and we’re talking a pile of dandy’s
Loads of dandies. You could play "the floor is lava" and not get your feet warm. Someone with more sense would have hit it twice with sweeps ahead of the drill.
Drought hardened dandies don't die they just take a break till next year. Couldn't get the fall burn down on due to the weather. I've got one bean quarter that took like combined 4 L of 360 gly, sencor pre, and 6g of express, still has the odd survivor. I'm pretty sure the cultivator is more moisture conserving at this point.
Where are you located? Will it even have a chance to make it if it's only in the 2-4 leaf stage right now? It wouldn't make it here for sure, even barley would be hit and miss. Nothing really completely kills dandelions in my experience in crop, only suppression, best time is post harvest, the later the better.
Discussion Starter #8
North/central Interlake
Have had beans make it, seeded on the 26th of June, not too worried about the wheat.
Crop insurance seeding deadline was the 20th, went in on the 12th after we finally gave up on the canola but was so dry it didn't emerge till it rained a week later. One section of that drill seems to have went slightly off vs the rest which is why it's 2-3 leaf in some rows, came up 2 days behind the rest of the field.
You are at the right stage to spray Banvel, 2-5 leaf, but the dandelions are probably too big but what other options do you have. Dicamba in any form is very hard on the crop so how much of a setback are you going to get to a very late crop? I was just going through the Blue Book looking for options to spray the lawn around the farm and there are not many good options to even suppress dandelion, specially big mature ones. The book limits control to 15 cm diameter and 25 cm tall. I am thinking they are a lot bigger than that. Same on my lawn. A couple of good options for the lawn are Curtail M (clopyralid and MCPA ester) or Refine and 24D ester. Would those be safer on your wheat than dicamba? Another newer and good chemical could be Infinity (prasulfotole and bromoxynil) that lists dandelion as controlled in the smaller stages. Tundra is another one that I have no experience with that has bromoxynil and pyrasulfotole along with fenoxaprop for wild oats. Out of all these Refine and 24D would almost be my first choice for my lawn and maybe your wheat too. Buctril has always been an easy chemical on the crop and gets a pretty good hit on the spectrum of the old weeds like dandelion. Just top up the Buctril with MCPA to 8 oz/ac. Let us know what you do and how it worked.
Had good luck with simplicity and refine on dandelions this year. Dont know the rate of refine added though.
1 - 11 of 11 Posts
