Not sure where to start...from what I recall, a cold morning, the feeder faceplate settled but ran several acres before noticing and it required a full cycle to rephase the cylinders. This is pretty uncommon for this 740 to require this. Has a 40' fd70 with headsight tilt kit installed.
Next thing I notice is the header slowly tilts to the right when I turn around. The only time it quits tilting in the air is if you manually disable tilt by tapping the tilt switch, then it quits tilting. After a couple days of this, I adjusted rod linkage on headsight sensor to get it to stop. These have been trouble free and look ok, so I don't think it was the proper "fix".
Also, about 10% of the time, it struggles to fully tilt to the left, sometimes not even tilting fully without helping use the opposite end of header for leverage. While typing this, I recall hearing about making sure the bottom two bolts aren't tight. I should check that.
My main questions are how common is it for tilt cylinders to need rebuilt? They aren't leaking. Maybe the issue is with the valve body for tilt, though I am not sure how to verify. And lastly, why would it tilt to the right slowly when turning around, but quits if I tap the tilt button? These issues seem related, yet one seems electrical, the other hydraulical.
Why isn't hydraulical a word if electrical is????
