Like a lot of Western Canadian farmers, I am giving some Lentils a shot for the first time. I actually cropped and managed the durum crop the year before with the intention of trying out some Lentils, so I'm not purely just price chasing (although maybe a little ha). Anyhow we have been growing Peas for quite a while, and will still have a lot of pea acres going forward. The reason we have shied away from Lentils in the past is because we primarily grow either LL Canola or Durum on our pulse stubble the following year, both which are not good friends of the Clearfield production system. So to avoid that system I picked our cleanest field, seeded it to durum and then pre-harvested it. Planning on spraying Heat/Glyph for Pre-burn and then just Solo in crop, Priaxor and then finally either a reglone or straight heat destination (need the seed for next year, if this goes ok.).
Anyway I was wondering what the best seeding depth to use is, and most importantly to me, the timing of the seeding. Right now we are full of moisture and warm days are upon us. When we get to start this early we will usually start with Durum and then if its before April 18th (just a date we've settled on over the years, a very unexact science) we'll usually put in some peas before we start Canola. Are Lentils fairly frost tolerant like Durum and Peas? Would it be a good idea to seed the Lentils before we start on Canola or right around the same time? Regarding depth I have seen 1-2" from the SK Lentil Production sight. Is this the best or could I go 1/2" - 3/4" like Canola? We pretty much seed all our Cereals at this depth now as well as long as the moisture is decent.
Thanks
Thanks
