We have a new to us 560r and have a drago corn on the front. Trying to get the variable speed feeder house to work with the corn head. It will not speed up. Im thinking the the drago needs a "dummy" hookup for the multi coupler to tell the combine it has a head on it. Like the post below, I think I need to find the pin in the coupler. Thanks for respones in advance.
Just slow the feeder house down using the rotary dial then + or- that shouldn't matter. You are probably referring to running a reel. Then it needs to see a sensor before it will supply oil. Header and variable speed shouldn't affect it
Discussion Starter #3
2 Rotors, I think I tried the Cebis route, but still did not speed up. I was thinking also about having to use the reel sensor, but agree, I should be able to use the Cebis. Will do some more reasearch and reading. Thanks for reply.
