Can you engage the separator with the hopper extensions down? I was calibrating the header endstops with the headsight system in the shop, but dont have enough clearance to unfold the hoppers.
Yes, you’ll get an alert but just escape to cancel. Might only come on if you try to move come to think of it.
In fact you can fill it about 30% before full bin alert will trigger.
Simply lift extensions on the go to continue.
Thanks Don. I knew the grain tank auger was a gearbox, but just wanted to make sure. If I remember right there was an S series Deere around hear that did a lot of damage with the hopper down trying to cut under a overhead power line.
You’re welcome.
I occasionally do desperation sample taking during light showers simply leaving the top down.
Done to study quality factors not including moisture, ha ha.
I have come across some combine parts, in particular for a 700 wide body. Some of the threshing components, such as the concave and preconcave grates, have a "speckle coating" appearance. I can only guess this is an extended wear option, although I have never seen one in person for a Lexion. The...
I have had my 575R for a few years now. Love the machine but the service and parts availability suck. Took over a month to come out to service. Was thinking about trading it in for a CaseIh 8120 on tracks. Downfall? Don't know what to do.
ENGINE UPDATES available on CLAAS combines with CAT C9.3 AND C13 engines. Full emission removal available, no more down time and better fuel economy. Call anytime for information and pricing.
Wondering if anyone likes aftermarket chopper knives for a 740? I haven’t looked yet but my oem blades need replacing. Would need complete knives, bushings, bolts. They have been turned so both sides are rounded and wore.
Currently running 2 Lexion 760's in sunflowers and banging our heads against the wall trying to get our returns in check. No matter how we've set the combines we are filling our return elevator with sunnies that should be going into the clean grain.
Both machines have a TM6 top sieve and the...
