So last harvest the sieve box on our 770 broke apart on the left side right above the cut out for the clean grain auger. The machine has close to 2000 separator hours.
replacement costs $ 8000. We ordered one and at the time was only one!!! in stock in NA.
we parked the combine and installed it last week. We were told worn mega bushings in the shaker arm could be the cause. We replaced all bushings. the left side ones were bad but the right ones were still not bad. I understand that the whole cleaning is equally driven from both sides. But why has the left more wear?
So having almost done the repairs on the 770 we moved over to the 760 tt to replace the upper sieves with TM 6 sieves. Just to make sure this one has no problems we pulled the lower left sieve out and low and behold this box has a crack in the same spot going up to the angle where the sieve sits on. My son reached from underneath to feel the outside and the reinforced plate is cracked as well.
Both Combines are 2011s and the parts book shows this part # was only used in this model. I don`t know if Claas improved this ****ty poor design in the newer ones or not, the parts book shows the same image, just different numbers. All I found was the 480 had a different box and it looks a lot stronger. Maybe they weakened the sieve box when they put in the jet stream fan and the larger clean grain auger.
pics will follow
pics will follow
