Does anyone know the speed of the drive shafts on a fixed speed feederhouse on a 760? I need to adapt a jd 930 sunflower header to the lexion but need to be sure of the shaft speeds first.
On my tach it shows a speed of 430 rpm. sorry my combine is the 590r but i'm quite sure its the same for the 760Does anyone know the speed of the drive shafts on a fixed speed feederhouse on a 760? I need to adapt a jd 930 sunflower header to the lexion but need to be sure of the shaft speeds first.
It does Brian but the problem is that's not the feeder driveshaft, it's an upstream shaft. When everyone else measures it (logically) at the PTO connection point what a idiotic place to measure the speed!On my tach it shows a speed of 430 rpm. sorry my combine is the 590r but i'm quite sure its the same for the 760
We're both getting old...er Brian.Your right Don it is the intermediate shaft. I must be getting old. Lol
That seems odd because when we bought a corn head and put it on the lexion the head was running way too slow. It had jd gears in it. We had to change the gears in the head to make it run faster because the feeder house turned too slow.It does Brian but the problem is that's not the feeder driveshaft, it's an upstream shaft. When everyone else measures it (logically) at the PTO connection point what a idiotic place to measure the speed!
Yes, the 590 and 760 are the same and it's about 760 rpm at the feeder driveshaft.
For some daily trivia, Claas and Gleaner are about the same and they are the highest speeds in the industry.![]()
That does not make sense!That seems odd because when we bought a corn head and put it on the lexion the head was running way too slow. It had jd gears in it. We had to change the gears in the head to make it run faster because the feeder house turned too slow.
